A
andekoch
I am quoting on a rewire of an existing house (4 bed) where the owners will not be vacating while I do the work. So this leads to a few logistical questions that I would like your opinions on.
Am having to add a lot of new plug points (currently only 1 single plug per room).
1) what do you do for power and lighting while work is in progress and so the owners can cook and watch telly at night?
2) the owners want the existing plug points raised above the skirting level but not as high as the current 450mm above floor. My understanding of the building regs (part M) is that this is acceptable since the 450mm is for new build only and rewires can be left as they are or improved to make them closer to the current standards as long as they are no worse off the before the work commences.
3) also i am not allowed to lift the ground floor and need to work under the floor in the crawl space (mixing with the rats and spiders). what good ideas have you guys got to minise the time spent down there to run the new cables. I cant think of anything myself (other than send the apprentice down).
4) how do you channel behind the skirting boards. I am thinking of channelling down to the skirting and then drilling the rest so the skirting board can stay on.
so many questions so little time.
