C
Craig1982
I am just starting to get some tools together, I have alot of hand tools and a few power tools but was just interested to see what power tools other people have and which get used most/least and battery or corded? I could go crazy and buy loads of power tools but her indoors wont be to happy!!!
ok here's the plant I have
110v Devalt 5KG SDS drill/breaker
110v Ryiobi SDS drill
240v Borsche SDS Drill
240v Wall chaser
2 x 24v Panasonic drills (one semi retired only comes out when need subbies to use a sds cordless)
15.6v Panasonic drill driver
15.6v Panasonic drill / Impact driver
15.6v Panasonic Metal cutter
110v transformer
415v transformer
4 x 110v em florescent temp lights
16x 110v florescent temp light
I would recommend you start with a SDS cordless drill to start with and then a drill driver
I tend to use my cordless plant. if I'm drilling thru a thick or hard wall I'll use the big dewalt drill
better to buy a few good tools than a lot of cheap crap.
you need , in order of priority, ( IMO )
1. 240V or 110V rotary stop SDS drill
2. 18V dewalt or similar drill/driver
3. cordless SDS drill
4. corded or cordless circular saw
5. wall chaser
6. now you can start fantasising about fein multi tool, cordless angle grinders, inspection cameras, and the like.
I just buy em as i need em and probably whatever deal is on at screwfix at the time, my hitachi 110v sds was a good buy tho, got a real torque to it a solid blows per min when on rotary stop, great for chisselling walls.
Cheers for the replys, I am going to buy alot of things as and when I need them. I have a little cash buring a hole in my pocket so I think I will go for a SDS and 18v drill, now to see what deals are on :sunny:
none of my battery plant is Li-ion,
if I was buying new or replacing mine, I would be looking a Li-ion plant
me too my old ni-cads are holding charge less and less, also alot of peeps i know are using impact drivers these days and they do seem to be the nuts
What do you use impact drivers for when doing electrical work?
My Makita Ni-cad has just about had it, Ni-cad batteries do not last long IMHO.
Depends where most of your work is - if house bashing a Wall Chaser, Good vacuum, Rip Saw (Circular saw), Kango are vital - but will be near useless in industrial. A good cordless SDS drill is a must.
Some items I have are cheap and nasty (The rip saw is a £30 effort, but generally only used on floorboards).
Can get decent replacement batteries from flea bay - non branded mind! My little dewalt combi batteries gave up the ghost after about 5 years, 2 replacement batteries are still going strong after 2 years.
For cordless tools, try to decide on a range and stick to it. Then you can use existing batteries and charger on body-only tools later. I've used Makita 18V Li-ion for the last couple of years; very pleased with them.
Cordless SDS is great for cable holes and fixings in tough brickwork. Also with a chisel bit for chasing.
240v Wall chaser
110v transformer
415v transformer
240v drills!!,were not even allowed 110v,cordless or nothing for us..
