P
Plonker 3
I thought the whole point in installing a fan isolator was for one reason only, if the fan is installed in a room where there is no window, and the fan is wired from the lighting circuit, it allows you to isolate the fan without isolating the lights, hence giving you light to work on the fan.
So how do you cope when its dark outside? Or work on a faulty lighting circuit?
