Hi all is this ok to run two sfcu like this ?
Or should i run it like this
engaged mouth before brain .......................there
Haha all the different answers..... Goes back in the arms to see Malcolm's other thread
Appendix 15 in Green Book shows no issues? Why do you need the 13a FCU at the beginning if the switches are FCU's with 3amp fuses in?
Sigh, yes either one is fine really but first option probably the best no need for fusing down to 13a first if your fusing down to 3a
In wich case can you give us an explanation as to why not, I'll be very interested in your reasoning
Admitedly I`m assuming the socket it on a ring as apposed to a spur from a radial
Well its a spur, and unfused at its source, therefore as i understand it. OSG Page 68 (7.2.2)
" A non-fused spur feeds only one twin socket outlet or one permanently connected item of electrical equipment"
Yea but it's fused with the 3a sfu??
Maybe you should look at the pics again. Neither picture is showing a spur that isn't fused
