O
oldtimer
When doing a CU change I always put the garage on a stand alone RCBO and I wire it to a 40A DP neon switch below the CU and I tell the customer that the garage is stand alone but because the RCBO is quite small you may not notice that it has tripped but the neon on the DP switch tells you when it has.
