R
Rauer
Just been asked by a customer if this is the case!
Their previous electrician had told them that the regulations stated that all redundant cables now have to be removed !
Surley I can't tell little old dorris that I have got to chisel her wall out to get the cables out that used to feed a socket that is no longer live after a rewire???
never heard of a requirement to rip out redundant cabling.obviously I would remove any that could be done so easily but otherwise isolate block the ends and label up.
As above it falls in line with metal recycling in houses regulation!
Sent from my GT-I9300 using Tapatalk 2
I didn't think it had been introduced into the regs but thought for a slight moment I might of missed it! But clearly not!!
Its in mine. possibly in crayon in the back but at £4.35kg it had to go in there. Thats why so many pages are blank, so we can add our own bits in that suit. ;)
Good practise to remove it, wouldn't go over the top to get it all out though. "regulations stated that all redundant cables now have to be removed", total BS
I was taught that it's preferable to remove redundant cables if possible, to avoid unnecessary confusion. They should have been taken out during the rewire though, when the walls are being chased anyway.
I don't think there's any specific reg requiring you to, it's just common sense - 'out with the old, in with the new'.
Rauer,
Fin170,
