Do you install a flylead to metal backboxes??
  • Yes
    Votes: 28 63.6%
  • No
    Votes: 16 36.4%
  • Total voters
    44
basically the metal back box requires earthing , it relates back to regulation 8 of the electricity at work regulations 1989
which states precautions shall be taken ,either by earthing or by other suitable means as to prevent danger ,
i.e a danger could be present if a line conductor comes a drift we need to make sure the fuse or breaker disconnects ,
again 99 times out of a hundred i will have say 3 earth cables in a ring main socket earth terminal the reason for this years ago i looked at the risk of people getting say an electric shock and decided that the larger risk came from the accessory metal plate or plug or after the plug so common sense dictated the lowest path of resistance would be connecting all three earths together ,plus over time doesnt the damp and plaster turn the metal back box terminal green increasing the resistance of that connnection
please also note i still consider myself the apprentice at 49 years old , cheers
I've always linked to the box, another way of looking at it is why do they fit an earth terminal if it's not going to be used? manufacturers would save money by deleting it.
No it doesn't.
The EAWR only applies when an installation is being constructed (but not if it's the householder doing the construction), or if the installation is or will become a work place.
i'll be the first person to say i don't put a fly lead on. No need to and those that say it only takes 10 seconds longer are dreaming. You must have good prices in. Switch of supply before removing cover applies to sockets aswell
I was taught to do it as a boy apprentice, when I queried it because of the metal bolts/fixed lugs I was told that it wasn't strictly necessary but that it was good practice. Nigh on 30 years on I'm still doing it for that reason and until someone convinces me otherwise I'll continue to do so, old habits die hard and for the time and materials it uses why the hell are we discussing it? Just Do It:)
ive seen it done 2 ways,1. flylead to back box and 2.one earth from ring to back box the other to socket and link in between,but always taught to earth back box no matter what
I put them in the box before I fit them, does'nt take long.
I agree Billy, it adds about 1 minute to each box, not 10 seconds....
No need to "technically" do a great many things in life, but they are good practice, and in many cases make life easier down the line for someone.
Billyhas, there's no need to look both ways when at a zebra crossing because the drivers are legally required to stop for you but we all do don't we
I use the one leg of the ring with 2 bits of sleeving, just doubling it over into the back box lug and then into the socket when doing twin and earth, literally takes a few seconds longer.
When doing singles I use a seperate lead and put all 3 into the socket terminal.
actualy i always have and always will the reason being if customer replaces plastic to metal and does a poor job of connecting cpc to faceplate my backbox connection hopefully touching faceplate either by screw conductivity or physical contact may insure a good earth path in case of a fault.
however maybe someone needs to do some resistance checks because the metal switches are laquered and that may have an effect.
i usually conect first to back box then to socket or switch,but as mentioned on here i have seen old wirring where cable has deteriorated in box via grening of cables or even rusr
Strange anology. Do you really think there is no need to look both ways at a zebra crossing?
