If you carry on assuming it is working correctly via a lead and are not prepared or may be not equipped to carry out proper testing then I'm out
I am perfectly prepared and equipped to carry out proper testing, and have tested everything except the earth impedence, which I am carrying out tomorrow. I am NOT assuming it is working correctly via a lead, it does the same on the ring socket as well, going off after 'x' amount of time, that is the reason I am on here asking if anyone else has come across such a thing. Two heads are better than one, so they say.
I have tried 99% of the things I can think of to work out why it is only working correctly on the lead and have not come to a conclusion. I am certainly not a 'cowboy Electrician' if that is the implication, if that were the truth, I would not care either way, and would leave it working on the lead.
Just here to clarify that you have said you have already changed the socket to a twin... you will have already done an ELI test to confirm the correct safety of the socket... but reading further it dosen't seem to be the case, although disregarding this i dont think this is the issue but im inclined to think the product is at fault... submit a cert' for the circuit that it is within reg's and let the chairlift company worry about the charging issues.... if you dont youll be going around in circles trying to find a fault that isnt on the installation side.
I agree, if you have done all of your tests and results are satisfactory then it is the stair-lift company/manufacturers problem.
Just a thought..... and this is a big think...... what IF there was a polarity cross-over on the manufacturers side (which might explain the symptoms??) AND purely by chance the lead you've got also happens to be cross wired.... so in other words it inadvertantly corrects the problem.
BTW, this suggestion is incredibly far fetched, but truth is stranger than fiction sometimes.
See you angle here but from the OP explanation it charges for a few hours, if the charging circuit was polarity conscious it wouldn't charge and its also a rectified ac to dc signal so it wouldn't be a problem as irrespective of ac input the dc would be correct due to the diodes in the full wave rectifyer. I feel we either lack the full info or the battery/charging system are at fault.
If the extension lead was not earthed (two core cable, etc.) and an earth fault occurs in the transformer once it has got hot after running for a while then the system may not recognise the fault as there would be no return path but there would be an earth return path when plugged directly into the socket?
Thanks for all the help folks. I am on my way over there now. I will get back on here later and let you all know the outcome. Some suggestions here that I can certainly try and it has been great having others pitch some ideas in.... Much appreciated. Phil
The thought in my head was if the charging unit is fine to actually charge with a polarity issue (as you say, it's just rectified DC at 14ish V), but if the SENSING circuitry was in some way polarity affected. But, as I said, this is an incredibly large pluck on a very fine straw!!
