had some feeding wall-lights a couple of years ago during a refurb - ir tested better then some of the pvc cables
One of the first things I was taught when I was an apprentice was to put one hand behind your back when cutting lead cables.
one of the neighbours has it....still in service after god knows how many years....
when i rewired my mothers place down shrewsbury there was a lot of it in there...together with some very crusty VIR..lol...
2 weeks ago I was in a place that had lead cables running about the place, couldn't find any live
Also had some of the cotton insulated in wooden trucking stuff going about as well
Wondered if I should of took it out and handed it to a museum :lol:
well ...i suppose the science museum would have had it...
theres a load of cloth cable at this mill/factory i am currently working on....it was feeding a dis board for lighting...on each floor (4 floors)....
My house had loads of lead cables, as well as VIR, all unused, but I just can't be bothered to remove them. I have cut off most off the visible stuff in the cellar, but there is loads in the fabric of the building. It might actually be holding the place together!
holding the place together eh..lol.....dare you have a weigh in?..lol...
Removed loads of lead earlier this year after a BG loft insulation team took a deep "sucking through teeth" breath as they downed tools....
lol...what would a bunch of plumbers know about our cables?..lol...
- - - Updated - - -
and loft insulators?..lol...
Feeding an immersion in Holyhead last August , once I removed the lead sheaf , the cloth insulation of the conductors was still waxy, almost like new, I did and IR test.....about 155 Meg I think for a 15 metre circuit
Yep,still have some functioning lead in my old 1937 gaff.Will get my man Hector to check it out when he returns from the opocathary with my laudanum.
I am going to a job this morning which has lead sheathed cable and cotton cloth covered wires. It also has a new 17th edition CU. I thought with wiring this old it should be condemned and replaced. It might be 60 to 100 years old. Am I to assume if it is working fine and testing fine it should be left?
It is in an old tenement in Glasgow with beautiful plaster cornices and ceiling roses. The customer bought the flat two months ago and if it is to be rewired ( lighting only) the mess will be horrendous for them.
I would assume that whoever installed the CU would have left a test cert. but somehow I doubt it, as I think the new board was simply to make things look ok for selling.
