spot the errors one on the earth lable of a consumer unit still trying to figure
out the numbering , the other is how scottish power wired an isolator ,not the out going they are tempuary well done scottish power
They have used the numbering on the earth / neutral bar to align the tails.
Surely if they are tails then they go from the back to the front, seems likely!
Those numbers must be the bar code that takes you to the website that gives you the link to the download of the numbering system code that translates the numbers to letters and the letters to numbers so that the sequence is correct....
it seems so obvious now!
I know what you're saying, but who's fault is it in the first place. What colour do you associate green and yellow with? The bar doesn’t appear to be insulated.
