B
bluecallum
Hi am thinking of wiring my outdoor shed with a few sockets and couple of lights,electrician says he would have too wire in 16mm armoured cable and put a 2 or 3 way consumer unit in shed is this the right procedure as the shed is about 15 meters away from the house,and a isolator switch by the main fuseboard in the house,it seems a very expensive way for a shed
Depending on what your loading is 16mm armoured seems a bit excessive too me,you want isolation in the house and it needs to be rcd protected also.there are other ways to do the job,also the work is notifiable under part p.Why not post your location and let one of the lads on here give you a price.
What did you tell him you'd be using the shed for? He wouldn't have been suggesting 16mm for no reason.
May be you should get another estimate done.
Edit: just read a couple of your older posts which suggest you are a sparky??
it was going to be used for my wifes glass etching business what size armoured would you recommend
What would be a reasonable price for three lights and three sockets and consumer unit wired in the shed which i reckon about 15metres of cable
Who knows.
Only you and your wife could possibly know what the power requirement is!!!!!!!!!
Maybe you should put in 25mm just in case. lol
- - - Updated - - -
At least £320.00 plus any necessary changes to the installation within the house.
I suppose the electrican has to safeguard himself I can see that he probably thinks that in the winter a few heaters may be plugged in,so would you say 16mm armoured is still over the top
My guess is, he's taking a feed straight off Henley blocks by the meter, going through an non fused isolator . That's why he's using 16mil.
If the sockets are 13A Duel Sockets and the lights are standard lighting (on a 6A MCB) then I would guess that a 10mm SWA should be more than enough.
Thinking 3 x double sockets (32A) and 3 x standard lighting (6A) thats 38A in total. A 10mm SWA can handle that easy.
He did say he would have to come straight off the mains with henley blocks because there are no spareways on the fuseboard
In which case the price would most likely be higher.
Good job you're not doing it as your wife can off set it against her business!
bluecallum,
Octopus,
