T
thekingiam
local doctors want light fitting replaced,light costs 35 quid labour about an hour.
it's a double flourescent with metalic diffuser that slides in, problem is wont be able to slide in side ways as the walls each side are in the way. the fitting it replaces was bent out of shape to get diffuser in.
don't want to do it with surgery open as lights need to go off and alarm probably connected to lighting circuit.
also don't want to trip rcd and all their computers go down.
already been there before for an hour looking at problem?
£150 for out of hours? just a ball park guess..... only you can decide really.
If you want you can do Materials + 10% mark up
2 hours labour inc travel @ £24ph for out of hours = £48 + 20% mark up
Probably gives about £100 or so.
Personally my call out for first hour £45 + [materials x 20%] + vat = £105
I like this, it is a formula that you can use with all customers and therefore it is fair. Thats your price, no need to waste time discussing it. No to make it up on the spot. If someone else calls up your wife, colleagues or apprentice can give similar prices to people, plus if another person known to them calls you with a similar job you are much more likely to give a similar price.
She said £50! How was that arrived at? Just plucked from the air by any chance - that's unprofessional imo
came up with£125 marerials i thought cheap don't rhink they come with tubes and starter so priced at £60 instead of£35 pluss labour £45 + out of hours service extra£15 = £ 125.
i don't mind not getting job as it's a difficult job.
Depends if you want to get the maintenance contract for the surgery, and remember doctors work in cluster groups covering other surgeries out of hours, I would do the Job for 100-120 plus vat and be very friendly, you may get a few grands worth of work from this one day when they expand or have alterations done inside the surgery, I started doing bits for libraries and schools this way and get loads of work from various libraries and schools now, Just another view about this particular job.
yes you defiantly have to have a pricing structure, it makes things alot easier when people ask you a cost beforehand, especially on faults etc
i personally wouldnt charge any extra for an out of hours call for a job like, that as mentioned above, i am always looking for their future business and recommendations
i do work for my local doctors surgery and all the little jobs i fit into their lunch gap between 1 and 2 oclock when they shut
also as mentioned above their whole board is protected by one RCD and i allways sweat when i know ive only got an hour and im trying not to trip out the whole place too with a careless N-E cross
if your interested i have included my pricing structure below
1 day electrician and mate £350+vat (8 hour day)
1 day electrican £200+vat (after 5 hours and up to 8 hours)
1/2 day electrician £125+vat (after 3 hours and up to 5 hours)
£45 1st hour call out and £25 hour thereafter
All materials supplied at cost plus 20%
How does this compare with yous lot? interesting to see what other people are charging
