Dean Williams
i've installed it using the steel frame and i've seen countless steel frame factories new and old wired the same way.
Yes that would be acceptable.If you had a steel framed building with the electrical service at one end and the gas/water service at the other end. Would it be possible to bond the steel as normal, but then just bond the gas/water service straight to the steel work, instead of taking back to the MET.
Been doing this for 28 years on large construction sites gas and water still bonded so i am not naive but you obviously think you know it all lol
I agree, use the steel as a bonding conductor. If you fancy, you could use it as a common CPC too!
