Depends who owned the flat when the work was carried out, glos council went through a phase in the mid eighties where every premises they owned which became a dwelling was rewired in Pyro, houses, flats, care homes etc, so it may have been a council flat back then and hence the pyro.
In the 1960's we always wired council property in pyro.
This also covered public buildings, churches and when we worked on them Boiler Houses and Warships.
nearly 70years of age and I can still make a pyro end off with a pair of side cutters, potting tools, and hand crimpers.
Its so easy.
Problem is they do not teach these skills any more, in fact modern day apprenticeships are NOT apprenticeships but training schemes.
One needs a Day to Day mentor for on the job mentoring ( Vocational training) different from the underpinning knowledge learned in college
Unless people 'install' it with no glands!
You must be a young'un....lol!!
There is a system for using MICC cables that doesn't require glanding at the accessories. The wall and ceiling boxes are provided with pot clamps that securely clamps the made off pots to the boxes. The only glanding on such systems are those to the CU/DB....
Well, I also didn't know about them but I was actually meaning the SWA that doesn't need RCD'ing, unless it's like the one i saw today connecting to four outside floor lights each connected with the armouring just taped off! Wouldn't like to be the one putting the spade through the one midway along!
Well, I also didn't know about them but I was actually meaning the SWA that doesn't need RCD ing, unless it's like the one i saw today connecting to four outside floor lights each connected with the armouring just taped off! Wouldn't like to be the one putting the spade through the one midway along!
I really must read posts more carefully!! lol!!
I suppose the SWA you mention could have an internal CPC, but your right the armouring still needs an earth connection, throughout it's length...
Engineer54 Totally agree with you.
Installing Pyro with glands is only required WHEN and only IF there are Female Sockets to screw the gland into. Otherwise use the clamp system.#
These young uns would not know that, but they must remember to paint the clamps with galvafroid / anti rust compound once it has been installed IF the clamp outer face has been damaged by grips as it will then rust.
This is another part of the training that is not taught, how many install black Enameled / Glav conduit but DO NOT paint over the screwed joints ???
