P
Poshspark
Hi I have been looking at a 1950's flat which is wired in pyro so would this mean RCD protection is not required?
Discuss Pyro in a flat in the UK Electrical Forum area at ElectriciansForums.net
I thought that piro's do need rcd protection because they are not adequatly protected in the wall like cables in conduit are?????
Stick a nail or screw thro' Pyro and what happens??
I would still RCD protect the cable as the copper sheath doesn't provide enough protection from penetration of nails or screws.
Why would anyone in their right mind wire a domestic in pyro?
Unless people 'install' it with no glands!swa wont stop a nail either but doesnt need rcd'ing.
Well, I also didn't know about them but I was actually meaning the SWA that doesn't need RCD'ing, unless it's like the one i saw today connecting to four outside floor lights each connected with the armouring just taped off! Wouldn't like to be the one putting the spade through the one midway along!You must be a young'un....lol!!
There is a system for using MICC cables that doesn't require glanding at the accessories. The wall and ceiling boxes are provided with pot clamps that securely clamps the made off pots to the boxes. The only glanding on such systems are those to the CU/DB....
Well, I also didn't know about them but I was actually meaning the SWA that doesn't need RCD ing, unless it's like the one i saw today connecting to four outside floor lights each connected with the armouring just taped off! Wouldn't like to be the one putting the spade through the one midway along!
Reply to Pyro in a flat in the UK Electrical Forum area at ElectriciansForums.net
