Stop blagging? If that means you think I'm lying your mistaken. Electrics is a module of my course... And this was a question I had? Was just asking for help with it... Surly if your not prepared to help don't post on my post pleaae
If you've got 33kv to your house start worrying,imo you appear to have difficulty understanding the questions.
hi, phil, how's the gsd bitch coming along?
nat grid 400kv?
sec trans 132?
supp in industry 11k
dis networks ermm??
comercial 415?
domestic 230??
You are getting closer with the above, you need to know the "standard" voltages.
Think on this: The transmission of power is at the highest (400-132 kV), distribution of power is at lower high voltage (33-11 kV), supply to customers is either three or single phase (400-230 V).
Apply the appropriate voltages to the appropriate areas.
Hi all.. can someone answer this question please,
State one standard voltage for each of these
1- national grid systems ...400/132KV ...take your pick!!
2- secondary transmission systems ...66/33/11KV...take your pick!!
3-supply to industry ...400V /11KV ...take your pick!!
4-distribution networks ...400V
5-supply to commercial building ...400V/11KV take your pick!!
6- domestic dwellings 400/230V ...take your pick!!
thanks in advance
The question as it's written above is open to all sorts of interpretation and in most cases have several correct answers. Question 3 for example could even be 33KV for heavy industries such as steel works...
1- national grid systems 400 / 275 / 132 KV
2- secondary transmission systems 132 / 66 / 33 KV
3-supply to industry 33 / 11KV
4-distribution networks 400 / 415 / 433 V
5-supply to commercial building 400 (230) / 415 (240) / 433 (250)V
6- domestic dwellings 230 / 240 / 250V
thanks in advance
I've taken it a step further. Simply because the UK power distributors don’t abide by the 400 / 230V European directive. They cant afford to go around changing 10’s of 1000’s transformer just because some idiot in Brussels says “it should be!”
Sounds like someone can't be bothered to google it or read some books
you try find single answers for them if just tried searching for him u wont find chrish :S its hard because there is like 2 or 3 answers for each of them haha. it depends on the person who is testing them how strict they are. and btw who knew trying to ask for help could start to to into bitch sesh :S if don't want to help just don't post at all guys it isn't hard....
erm industry for some reson i have 415 3 phase in my head???
