9regnac
Hi. I went to look at a cu change and the board is under the stairs. There's only room for an 8 way board which would be fine due the angle of roof. He had old elec heating and all points are now sockets which is fed off another board as normal. Both boards are fed to Henley block as normal.
Obviously I could just put in an 8 way and a 5 way rcd protected as there is no room for a 13 way.
Any other suggestions
