MDJ. Thanks I did not know that there needs to be an isolator to isolate both supplies at once. Will the main switch on each consumer not do. What reg number is that.
Cheers
no if you have 2 consumer units bud you need one isolator to be there for both, not sure of the reg at the moment, I have put my BGB back in the van, but now you have asked I will try to look tommorrow if I get time.
TBH, i can't find a reg. for that. looking at 537.1.4 it does not specifically stipulate a single isolator.
You have the advantage over me as my book is in the van, however I'm fairly certain all electrical circuits need to be isolated at one source, I will have a good look tommorrow and post either way.
Quite right Tel My apologies, on this rare occassion I'm wrong :smilewinkgrin:
or perhaps a reg that was there once is no longer, that reg you stated could be looked at in different ways, however regardless of that I found a reg stating if there are mulipull supplies or more than one if you like a labell must be installed at source, so bearing this reg in mind it must be fine to do what the OP suggested, therefore bag on head time :13:
