A
almac7
Have done what you said plugging them in one by one and all were ok until I switched on the outside light which doesn't have a bulb.yes you can, but if it won't hold in, then you have a fault . if that is the case, eliminate the appliances by unplugging them all then plug in 1 at a time. if the fault is still there with all appliances unplugged, you need an electrician to trace the wiring fault.
