Fell off a podium doing a shop fitout the day before the handover.Went through the false cieling and reached out to grab the nearest thing to stop myself breaking my neck.Just happened to be a sprinkler head.Pulled almost half the cieling down and damaged the sprinkler system.The entire job came to a halt and about 70/80 blokes were standing there laughing at me.The site manager was gong ballistic saying he wouldnt be able to handover to the client in the morning.Got sacked on the spot and left the site in disgrace
If i look back over the years i could go on and on
The only possible reply to that is...
hahahahahahahahahahahahahahaha
Capping off a rewire and putting the capping nails through the cable
Second fixing sockets after plaster and instead off cutting only the insulation cutting live and Nuetural along with it.. That really got to me that day..
I hate it when the apprentice is at collage.. Being colour blind its 50/50 weather its going to go bang..
I've done that too a cooker outlet, it's amazing how far 10mm stretches if you pull it hard enough
Drilled into wall to fix back trunking in vets utility room, hit buried water main to upstairs flat. No way to have spotted it. Found stop tap outside eventually, split thumb open trying to turn it off as it was jammed. Struggled to repair, clean up and finish job whilst wet, cold and injured. A day to forget! F^€%ing plumbers.
I’m perfect. If I wasn’t then maybe I’d confess to god. But I’m an atheist so I’ll just stick with being perfect.
Fitted 15 ish downlights in a room, perfect job, all went well. Homeowner came back and pointed out it was the wrong room.
that 1 reminds me of a council rewire in a day team. went to the wrong house and rewired it in the day. turned out that the house they rewired had been bought from the council by the tenant 12 months before. they tried without luck to get the owner to pay for it. he said that it's their mistake and showed them the door.
:fuk2:
I accidentally knocked a laser level off of a wall with a pair of steps.
My foreman mentioned it the next day, and apparently the cost of the unit varied between £3000 and £5000.
Needless to say, I did not pay for it.
On a job in Chester at a chocolate factory, I mixed up a couple of cables.
I connected the cables for valve No. 1 to the control panel for valve No. 2.
When they started up pump No. 1, valve No. 1 stayed shut.
Eventually the pipework between the pump and valve exploded with liquid chocolate every where.
That apparently cost about £15000 in replacement parts and loss of production.
Fortunately I was not asked to pay anything.
My brother whilst changing a socket-outlet front, got a belt off of the live.
He dropped the cable quite sharpishly and it touched a central heating pipe causing a flash and then the pipe started leaking.
This was in an occupied flat during a re-wire.
He then spent a few minutes trying to stop the leak with his thumb, whilst jumping about gettin belts through the water.
Turned out, that the main switch had been wired with reverse polarity, and he'd isolated the circuit at the SP MCB.
Went 10 years without ever hitting a pipe, then in the space of 1 month hit 2 water and 2 gas all on different jobs. Not hit any pipes in 9 years since.
