Trusted the word of someone else alone on a control panel being isolated. Confined space too, worked more or less sat inside of the panel for about an hour. Many 3 Phase connections etc. Finished and went to turn the machine back on...noticing it was never off. Never again. :33:
When i was in the Navy and working on Joint Force Harrier , we had an instruction in to check the main contactor terminals on a the Harrier battery main contactor. I sent one of the RAF guys who we were stationed with at the time out with the instruction leaflet to isolate and disconnect the terminals so that i had access to inspect them. 30 Mins later he came back in and told me that he was finished and I went out to the aircraft and poked my head and chest into the access hatch, which is also quite a small space.
As I brushed aside the cables he had disconnected I was caught up in a shower of white sparks, a loud buzzing noise as the battery discharged itself through the airframe, this only stopped after the part of the airframe that the cable had tried to weld itself to actually melted and allowed the terminal to fall away. I was luckily wearing protective clothing and just recieved a few splats of melted airframe to my hands and chin.
I have no idea to this day how he managed to take the terminal off with battery disconnected or even without seeing a few sparks as he did it, but he did. I can't imagine he did it again after our 'little chat'.
Got L & N Tails the wrong way round in the meter on my first ever fuseboard change, plaster went flying off his hopup. whoops.
Anybody want to buy one?
I cut out for a double socket once in a plasterboard wall and when the final cut was done and i pulled the piece out to my horror i could see into the next room! The walls were just two sheets of plasterboard dot and dabbed back to back as a wall! Up til then i'd not seen a house built like this but i check everytime now, i never did get to fit that socket
What a crap way to build a wall. I once drilled through both layers of a plasterboard wall, can't use your excuse though, there was a huge gap between the boards. Luckily, the room next door was due to be wallpapered...and it was also my own house!
that 1 reminds me of a council rewire in a day team. went to the wrong house and rewired it in the day. turned out that the house they rewired had been bought from the council by the tenant 12 months before. they tried without luck to get the owner to pay for it. he said that it's their mistake and showed them the door.
:fuk2:
That wasn't in Orpington was it? if so that was me
