H
highspark
Installed a dimmer and a couple of chandelier type fittings for a customer last year (11 months ago to be approx) didnt install any cables just added accessories.
Customer rings me today and says lights arent working. Just been and had a look and dimmer has. Blown.... Should I replace or ask customer to?
Dimmer is 800w btw! Not cheap
Depends, what warranty did you get when you purchased the dimmer? Is it fit for the purpose it is being used for?
Good customer service would say just replace yourself unless you can see that there have been alterations that have caused the dimmer to go faulty.
Not sure what warranty local wholesaler gives but will be a nightmare to dig out paperwork.
Why not phone them to find out? Did you get it on account or pay cash for it?
Do you not keep a copy of your books on file somewhere? I know it could be difficult to trace but at least if you have a idea when it was purchased you can look at the time on your record.
Could possibly be dug out but cant remember if cash or account to be honest. Far too many jobs done in between!
Could I say the same to my wholesaler? Just dug out paperwork so il get onto them!
I'd definitely try it on with the wholesaler, especially as you have the invoice and go and replace it FOC.
I suspect that the wholesaler will expect you to pay for the replacement and give you a credit when you return the faulty one,
Well yes, if it is under warranty the supplier is responsible for swapping the faulty item at no cost to yourself. you just have to provide the labour free of charge.
Problem is, the wholesaler is not going to compensate you for the value of your lost time in having to go back to the job.
Just out of curiosity, what make was the dimmer?
EDIT: Doh! Dillb beat me to it.
Re: Who's obliged to replace?
That is why you should have a mark up on parts that you supply , we do cost + 15% .
I was once told the industry standard is 33% but that sound a bit over the top to be honest .
Edit ;
A , Make sure it was fit for purpose , you don't want to be back again !
B , Make sure there has been no alterations .
C , Check they have not been trying to dim , non dimmable lamps .
A professional electrical contractor should always give a 12 month warrenty on any materials he supplies, nothing else to add I'm afraid.
I cannot understand why you would try it on with the customer any work done must be backed up by 12 month warranty that's the law. You wonder where the term cowboy comes from? Do you want a file opened on you by trading standards? Do you want to lose work by word of month when the customer telling friends and family you don't replace faulty parts?
It surely would be more expensive to spend time rummaging for the paperwork, go off to have an argument with the wholesaler, faff about with the credit note etc etc, when you could be earning money, than just buy another one and put it down to 'one of those things'.
highspark,
Rampantchilli,
