B
Buzzed
Hi everyone and warm wishes for a super 2013.
I have some questions regarding the grounding wire.
1. We have about 10 plug bases/points around the house upstairs and down. I used a tester (a neon buld screwdriver) and checked the ground socket in each of the plug-bases.
Other than in three or four, the tester bulb lit up in all others. While the ground wire in a few plug bases lit up blight a few were faint.
I observed that the tester light lit up bright when a ceiling fan nearby that plug-base was switched on.
The tester didn't light up at all in a few plug bases.
2. I have a desktop with a branded power supply (Cooler Master 450W). I noticed that when the power supply is connected to the plug base (while the computer is stil off), the tester lights up when it is held against any part of the computer metal casing. However there's no electric shock when I touch it by hand. Only the occasional short tingle/buzz. It's very faint though.
While the computer power supply is connected ( whether the computer is switched on or not), the current that the tester detects on the casing is also present in the grounding wire when I point the tester to the plug base.
Why could this be happening?
The earth wire is firmly grounded. All plug bases have three sockets for the live, neutral and ground wires. All electrical plugs also have three pins.
So why would the tested detect a current in the PC casing if the grounding is there?
You advice would be much obliged.
With kind regards,
Bezzed
With kind regards,
Bezzed
