M
MDJ
Total Rollocks, you changed a DB and didn't test anything, then asked which form to use, Quite frankly appalling, disgraceful in fact
So what are you results then bud.. Im bamboozled at this one..
Is this Sam BTW??
i am not called sam, my name is david
you want me to list my test reults?
because i was unsure what certificate to use
Not really but if you've done all the tests why did you ask the question?
without being rude or disrespectful...are you qualified?
It's a basic answer, and although i appreciate you coming on here to find out information, even if you are unsure it takes 30seconds to check in GN3 - it's clearly stated in their as to which certificates are for what.
because i was unsure what certificate to use, normally i use the EICR
possibly , but a bit hasty.
if he comes up with some credible numbers youre gonna look a right tool.
A condition report for a Distribution Change?????????????????????????????
yes qualified
ill refer to the book next time in case i cause offence
