Total Rollocks, you changed a DB and didn't test anything, then asked which form to use, Quite frankly appalling, disgraceful in fact
ok, whatever you say, was just trying to confirm the correct certificate to use. sorry to offend you
because i was unsure what certificate to use
without being rude or disrespectful...are you qualified?
It's a basic answer, and although i appreciate you coming on here to find out information, even if you are unsure it takes 30seconds to check in GN3 - it's clearly stated in their as to which certificates are for what.
possibly , but a bit hasty.
if he comes up with some credible numbers youre gonna look a right tool.
yes qualified
ill refer to the book next time in case i cause offence
If he comes up with some good numbers it means he has ability and should Know what certificate to use, I always look a right tool and couldn't give a Fluck Biff
southside elect,
southside elect,
