Intellect....why on earth would you be scoring girls on their intellect. Are you LOOKING to cause unbalance in the world. I think i remember seeing that scribed onto one of the Mayan scripts prior to their dooms day prediction.
"In 2012/2012, man will begin to judge the attractiveness of females...via their intellect...the world will be no more"
Hi when filling out a e.i.c. and it asks for maximum demand, is that the size of cut out fuse or does it mean working out all loads on circuits using diversity,shows what 2 yrs at college taught us.
It means using diversity, but there seems to be some debate on here as to which diversity to use. The OSG method is one, this seems to give quite a high max demand sometimes compared to the other method of x0.4. See below:
View attachment DNO guidelines on Max demand - GOOD.pdf
ps.. some will say your max demand is just whatever your cut out fuse is as in theory that is the max demand your system can take. I think this is cheating!!
If you have been to college you should have an IEE On Site Guide, If you have not got one...Buy one....It tells you how to work it out in there..the correct way that the IEE use
Remember where it asks for the supply fuse rating you write down whats on it dont pull the service fuse to find out.lol
Alot of the time its a bit of calculation and a bit of an educated guess, adding up breakers will just lead to silly figures
The main things to consider are heating and cooking elements etc
These will be the bulk of the demand in most cases then you need to take a step back and look at the installation and how it's likely to be used
Sockets are the most difficult to judge, but obviously a kitchen ring circuit will be a lot more loaded than an upstairs ring circuit
You can work out the Max demand for your lighting and apply a diversity that's realistic(but allways over compensate a little in every case)
then your basically just a massive pig charmer.
This must be me, as sometimes I just used to look at their body and go with that. Many years ago I did cop off with a lass who my mates tried to drag me away from, but she has great ----- and --- and was a really nice kisser. It was only until the week after when I saw her sober that she had a face like moon base alpha. I changed my ways after this and had to also check out the face...
All cats are black at night my friend, sometimes its best to let the beer talk.
However when a bird looks like shes bet set on fire and put out with a golf shoe and you could ride her into battle, lines must be drawn. Please refer to earlier post regarding socially acceptable limits of fugly.
The curves on a woman usually rule out socially acceptable mate.
The old rule of thumb of adding the ratings of the protective devices and multiplying by 0.4 should be adequate for your form filling exercise. Accurate MD is not an easy call, as some may think. Unfortunately this only comes with experience, as every installation is used differently. It even catches design engineers out on a regular basis, well (mostly) the younger ones anyway!! lol!!
Hate to say this but there's a lot of off-topic stuff in this thread, can we move it to chit-chat where it belongs! (tin hate and flame proof suit on!)
Back to the OP's question:
The IEE diversity calculations were fine when we used 6 way boards....... but we don't any more, so I think the add them all up and multiply by 0.4 is OK IMHO
