G
gnuuser
If i seem to post too much about safety I have good reason to.
its bad enough when you get a jolt.
but when you have to pull the body of a mate out of a substation the point really hits home
even more so when investigation reveals that he didn't follow safety regs and procedures.
you are all my new mates and i don't want to lose anyone else.
so i hope i don't drive anyone bonkers. but be safe my friends
Was that recent mate?
yes it was back in 1980 (prior to my military service)
gfci's /rcd's were not widely known in the US. and you rarely ever saw one.
its only within the past 15 years that they became a requirement in new service installs (if i remember correctly)
he had been lugging in new switching gear in a 12 kv. substation
he did not disconnect the main fuses and tried to do a live install
he also did not have the correct rubber gloves.
the coroner said it was an instant death
so, what habbened to using the sense you were born with then?..
hmm...
hmm...we`ll see...
Got to disagree with you there, ...GFCIs have been around in the States a hell of a lot longer than you mention here. They were requirements in the 1976 (70 something anyway) NFPA/NEC codes for certain area's in all new domestic installs. Worked with your codes over many years now, on various overseas projects.
Not that i think much of your MCCB's/RCBO's/MCB's, the tripping/protective curves on most of them are out of this world... lol!!
thats why ive named this post safety
i realize that our systems are radically different
but my point is their is no excuse for not following safety procedures
many of the boards we have to change here date back to the 40s and 50s some systems went back even further
we have to prove to the home owner that what they have (the old crap) is not safe
but we also have to work with whats available as far as new products, and we have to convince the homeowner that the cost is worth it
My gut reaction is you aren’t an electrician at all. Incorrect terminology, obviously no understanding of MV system operation.
It would be interesting if one of this boards moderators would confirm you’re IP.
Bit harsh Tony, I would imagine that there are quite a few electricians in this country who have no understanding of Medium Voltage system operation.
You also have to remember that it's a Yank you're talkinng with.
I watched an episode of CSI, and apparently if you cut the earth pin off of a plug, reverse the polarity of an a.c. drill then stick a nail or screw in someone's boot, they will die when they use that drill.
