B
Brightspark2
What problems, if any, do you see with this neutral setup...
L1, L2, L3 supplies taken from a large 3ph DB on 3 seperate 16A MCB's and 3 seperate 4mm cables, they enter into a contactor housing at high level. L1, L2, L3 switched by the contactor after which they go to 3 seperate discharge lighting cicuits. The neutrals of all 3 circuits are connected together in the contactor housing (Connector block). Similiar but not identical loads.
Work it out you're self
In=√((Ia²+Ib²+Ic²)-((Ia*Ib)+(Ia*Ic)+(Ib*Ic)))
Tony, I know you own this electrical knowledge, but could you entertain and enlighten the stupid (me) and expand a little on this. I had a ****s poor apprenticeship but am always looking to become better informed.
Thanks.
I own no knowledge. The formula can be found by looking.
RE the harmonic neutral current, without a power quallity meter or the data given by the lamp manufacturer it's near imposible to calculate.
What's the reason you don't use 3 double pole contactors and do the job properly.
The loads are unknown, I guessed at L1-10, L2-9, L3-11 and got 1.73A (That correct?). The loads may differ more, this is to settle a bit of a debate. Im geussing tony that because one neutral could handle the total neutral current then that aspect of it is ok?...
There was more to this debate though.
