B
Brightspark2
What problems, if any, do you see with this neutral setup...
L1, L2, L3 supplies taken from a large 3ph DB on 3 seperate 16A MCB's and 3 seperate 4mm cables, they enter into a contactor housing at high level. L1, L2, L3 switched by the contactor after which they go to 3 seperate discharge lighting cicuits. The neutrals of all 3 circuits are connected together in the contactor housing (Connector block). Similiar but not identical loads.
