G
Guest112
The biggest cause for me suggesting a rewire is when i look at a installation and its been altered a thousand times, nothing makes sense anymore.
I recently rewired a house, diddnt look too bad, all PVC cable, however there were signs everywhere of DIY bodges and indications that there had been a lot of fiddleing done in the past. there were a few interconnections on circuits and IR wasnt the best. the client had just bought the house and was planning on a full re decor, so i said what the hell you might as well have a rewire.
we pulled 36 JB's out of the house and the wiring was a total disaster. so im glad i went with my gut. if its too difficult to fathom what others have done and get a idead for the circuits and their contents, probably would benifit from a re wire.
I re-wired my house and have pulled out many junction boxes so far and they are the only ones I've found!! existing rings were bodged mixed between conduit in walls "T"ed off to feed 4 or 5 double sockets without protection via a fused spur, the consumer unit was fine, main rcd for an old merlin (didn't bother rcd testing as the paint was flaking off and planned on a new board anyway)
nut like you I went with my gut and decided as I viewed the house that it needed rewiring not because of an immiediate danger but as I am renovating anyway and there were bad practices/faults installed
atb
