I risk a ban/warning here myself, but I'm
sure I speak for everyone when I say STFU!
go and annoy someone else. no one is interested here
@ the op.
Are you the local electrical clerk of works on the job I'm on at the moment? Because he is a rounded door handle that does not know what he is on about as well!
Banning somebody for making valid and sensible suggestions/comments is just silly!
Banning people for being rude and offensive would make more sense and lets face it, so far many of you have repeatedly been rude and offensive.
Because your a knob
kingeri - you've finally made the point.
Small overloads for long periods is what we need to avoid - so current carrying capacity of 36amps and an I2 value of 46amps is wrong, you must agree.
Banning is not the way to go
Everyone is entitled to an opinion.even if that opinion seems foolish and comical to others
Banning for misbehaviour or foul language is understandable, banning for a poor opinion whether to promote argument or not.is not good
At least that's my opinion,I sincerely hope it won't also qualify for a ban
The current carrying capacity of 4.0mm T&E is 36amps (from memory) and the I2 value of a 32amp BS EN breaker is about 46amps (from memory), so what happens when a fault occurs or when the circuit is overloaded at 36 - 45amps?
The cable is overloaded and damaged prematurely!
Damaged/overheated cable has a reduced CSA making it easier to overload in the future, resulting in more damage and eventually fire.
Heating cable in itself is a waste of energy!
Ive pointed out the specific reg to read in a previous post what does 433.1.1(iii) say.... also the industry is built around decades of wisdom and calculation.... wouldn't you think that if your calcs dont match the common sizes of mcb found on these circuits and you actually find yourself coming up with values that dont match common installations then i would personally doubt my calcs or interpretation of the regs i.e. A 2.5 radial (installation methods allowing) is fine on a 20amp not derated to 16 as you suggest.
This would ring alarms bells in my head that i havn't fully understood what i calculate so by posting it in a factual manor you did you get what you deserve, if you use some empathy and post instead that your confused with your calcs the help would have been offered without the accusations of trolling.
Your confusing cable current capacity for a consistent load with fault current on the same cable for a fraction of a second. Look back at your college note if you have any.
Dan - how would you know what the majority are interested in when so few of you are making so much pointless noise?
- - - Updated - - -
There is no confusion on my part Paul.
No, because the utter, utter ball bags you posted doesn't warrant it. Why don't go write a book on how squirrel's are actually elephants, which are actually RCD's in disguise. Will fit in nicely with the other drivel you've "authored". EDIT:- An you need to lookup how MCB's work..clue it's a thermal thing!
Any chance of technical input?
David .... ive given you the answer to your misunderstanding twice now yet you ignored it...and continue to qustion why your post is incorrect....
I thus give up! :lipsrsealed2:
Darkwood - over many years the industry used BS circuit breakers which have a different I2 value to their BS EN counterparts!
Darkwood - you haven't answered anything you are just copying what people did before - using 32amp breakers. They've changed now mate.
What a load of total nonsense. If you can't post anything sensible then don't bother posting. I don't appreciate people coming on here trolling and trying to get a reaction from the forum members. Any more and you will be banned (AGAIN)
Thank God, A mod with a Brain
Yes but the calculations and adaptions to new products is all based on trial, error and scientific calcs of decades gone.... do you have a copy of the reg's i will ask you one more time to read 433.1.1(iii) there is a value there crucial to correcting your error... if you dont have a copy of the regs i question your competence as onsite guides are only for fast retrieval of the most common looked up areas and i seriously hope its not used as your full library of knowledge.
With opening post stapling out such table info which is incorrect will only make you look incompetent at the very least.
