M
Marvo
Okay I have a question for the trainees.
A friend of mine installed himself and extra socket last weekend. He dismantled an existing socket and drilled through the rear of the backbox into the adjacent room and surface mounted a new socket over the drilled hole and connected with a CAT5 cable. The only materials he used for the job was 1x steel backbox, 1xdouble switched socket and 400mm of CAT5e cable. Because of a difference in floor height between the two rooms the plugs wouldn't go into the socket because the cable in the plug was squashing tight against the floor. To work around this he mounted the new socket upside down so the plugs would go in easier.
How many regulations has he broken?
If you were filling out an EICR what codes would you give for the regulation infringements?
And before you ask I have no idea what the answer is so you'll have to fight it out amongst yourselves
