P
peteludman
If I was to install 12 lv lights what trip would I use because ohms law says 600w / 12v is 50A what equationshould I carry out
The 12v load is only on the secondary side of the transformer......if you are using individual electronic transformers on each light the total load is 600 / 230.
Ok so therefor there is no difference using mains or low voltage lights apart from whiteness then
