E
ezzzekiel
Found the ck to be a bit crap swapped over to wer and seem to be a lot better
Had my +- for about 10 years now. Bought them from RS components. They are "the" screwdriver for most CU/MCB/RCD/RCBO screws. Shame the Wiha don't realise this, as the Torque screwdriver set doesn't include them....
Oh yes they do, but only the Wiha VDE Torque Driver 18 piece set 2872T18 contains SL/PZ1 and SL/PZ2.
The additional interchangeable blades you require for the Wiha VDE Torque Driver are SL/PH1 Cat No. 33585, SL/PH2 Cat No. 33571, SL/PZ1 Cat No. 33572 and SL/PZ2 Cat No. 33586. Or alternatively SL/PZ1 Cat No. 35489 and SL/PZ2 Cat No. 35490 slim bits are available if you have the slim bit adaptor.
Insulated VDE tools /* Onlineshop /* Wiha.com /* Premium Tools for Professionals
Insulated VDE tools / Onlineshop / Wiha.com / Premium Tools for Professionals
So that begs the question, which type of screwhead do most MCB manufacturers use, Pozi or Phillips? Whilst I know the difference between the two in principal, I've never been able to tell visually, only by using either a PZ or PH driver and seeing which feels the best fit.
Thanks mate. I being a bit dim (killed a load of brain cells last night) but are these mystical MCB / CU etc bits the ones coded PH1 and PH2?
Looking at a philips head it has just two 'grooved' at 90 degrees forming a cross. A pozi head has a smaller, additional 'cross' at 45 degrees to the main one, more like a star.
Cheers, I think I've just been looking at different makes of PZ thinking one is a PH. DOH! What a muppet.
You're welcome, I'm sure I'll be called worse when I post my first stupid question!!!
