Q
Quinoa
Apologies if this has been answered before. Does a 3300 watt oven need to be hard wired or can it go straight into a 13amp socket?
Erm........what's the maximum current a plug top can handle........hint is in the maximum fuse you can put in one!
Edit: beaten to it
- - - Updated - - -
Plus, any appliance over 3kw should have it's own circuit anyway.
Again..... most of these ovens have a ''connected'' KW rating, that in reality cannot be used at the same time. A classic example is the grill element, it cannot used with the the main oven element and vise versa!! So in the real world it has a maximum of around 2.3KW or thereabouts, and not the 3.3KW stated on the box!! lol!!
I would personally have no problem connecting this oven via a plug top or spur on a ring circuit!! Though would depend very much on what else is connected to the ring circuit, in the way of fixed appliances!!
