HappyHippyDad
Supporter
I have been asked to install 6 downlights in a customers bedroom. The 3 makes that keep springing out at me are :
LAP, Robus and JCC
I dont like LAP switches/backboxes etc but thats all I know of them.
I intend to only offer fire rated ones but would be grateful for anyones knowledge of those 3 makes of downlighters?
As for bulbs!!! 90p for halogen or £20 for LED!! Thats a massive difference, are the LED's worth it?
Cheers all..
JCC I have used and liked. Good quality fitting and usually a cheap option too for the standard gu10 fire rated.
Avoid Robus like the plague. Cheap rubbish with thin brittle push on connection shields that break or even come pre broken.
I would also recommend iCage fittings from ansell as a quality gu10 fitting.
Led lamps are worth it as they last around 30 times longer get than halogen, and use a lot less energy. You don't need to pay more than a tenner a lamp for a decent one.
Look at megaman and kosnic.
not kosnic. i've had 2 fail after a couple of months. megaman are good.
If the customer can afford it then you won't go wrong with Haler H2 LED units. They're a dream to fit and come with a 7 year warranty (has to be claimed).
make sure you go for warm white ( 3000K ) in LED. the cool white are too harsh for bedrooms.
JCC is a 10 year warranty and the bezels (which don't eject easy like some) have the best finish I've seen
If I don't need dimming or it's in a bathroom I'll use them everytime. If I do need dimming then it's the LEDhut lamps and any fitting because the price is hard to compete with
Disagree!
Cheers guys,
JCC it is. I'm not sure what I'd do without this forum, I'm becoming quite attached to it and the characters within :smiley2:
HALER H2 ,if you have an account with wholesalers you shoud get pretty good discount if they stock them , £30-£45 depending in situation discount wise , 7 year guarantee cant fault them easy as to fit
