done it myself a few times. what is better , a TT with Ze of 150 ohms, or a carefully fitted BS951 to the cable sheath with a Ze of 0.3? i know which i prefer. although a proper spring clamp would be ideal, how many of us carry them on the van?
let me get this straight........
Nic say if you find tns earth connection by means of compression clamp then you cant rely on the integrity of that connection and should convert to TT.
ok , understand that clearly.
then Nic say code it a 2 ??
well if you've then provided your own earth then surely no code for the tns clamp as the dno earth is no longer relied upon ??
not thought through well was it lol.
Think the OP has perhaps not worded it well.....if it was an EICR it might be coded....not 'repaired' then coded!
I'm really tired and I am finding it difficult trying to understand why the nic are telling sparks to meddle with dno equipment, what's next being told its ok to cut the seals and remove the fuse ( at least I've heard of these mystical seals), next they will be saying just connect the main earth to the neutral in the head and turn it into a tn-c-s
They are not telling sparks to meddle with DNO equipment. They are saying a Bs 951 clamp on a lead sheath as a main earth is not a sound means of earthing,and should be either coded or rectified. A bs951 clamp on a lead sheath is unlikely to have been installed by the DNO!
I was on a job the other day were the DNO had to come out and PME the installation. When they put the new head in they told the customer that the tails from the meter to the cu were damaged from being painted and that all He (the customer) had to do was to CUT THE SEAL AND PULL THE FUSE!!!! then fit new tails....I laughed when he told me and said even Im not allowed to touch the service head, so why the hell is he telling you to do it??? Anyway, I told the customer, if the fuse falls out while im there next week, ill chage the tails for him.lol
Jay
Why on earth is anyone surprised that the NIC are dictating what should be done with DNO equipment? They write their own regs and are masters of the electrical universe, DNOs are mere amateurs by comparison.
Just follow each and all NIC directive without question. They know what they're doing so it'll all be fine.
BTW, are we allowed to swear on here yet? I think it'd be a really good addition to the boards feel and save loads of time. I could reply to each thread mentioning the NIC with five key strokes and two mouse clicks.
Then what? TT means changing the board if it isnt RCD protected. im sure the customer would love picking up the tab for that just because the NIC arent happy with a clamp :)
FFS!!.....do you really think the DNO would fit a 951 clamp???.....it would have been fitted by a sparks and not the DNO.
TBH even the DNO's can't be ar**ed. I went to a job the other day as BG refused to do a boiler change due to high Ze; sure enough 3.44ohms on a TNS. Scottish Power took five days to come out and another three weeks before they repaired the failing joint out in the street. I went back as BG had asked for written confirmation of the Ze - good, it was 0.22. Bad - the 16mm main earth to the CU had simply been jammed behind a piece of wire they had twisted round the cable sheath.
Customer complained, "supervisor" came out. "That's it sorted". I went back out and found it exactly the same. TBH a 951 would do a better job.
Another weapon 'lol'
Again as i mentioned i have had Scottish Power out several times and get the same answer so i am asking for peoples opinions on this.
I have literally changed thousands of consumer units, like to think i am very knowledgable
After an opinion, luckily mostly sensible people replied
Same here thats my general feeling on the subject
Why? Thats the problem with this place, every tom and dick starts i asked for an opinion
not the rights or wrongs, we are all singing from the same sheet here no?
Apparently we're not all singing from the same hymn sheet, as Wirepuller says above a 951 clamp on a lead sheath is not considered to be a sound means of earthing.
Suppose you bowl up to a place with a questionable earth reading, you whack a 951 on the sheath and over time it works loose. What happens to that reading you worked so hard to obtain? Or if you'd done this and something were to go horribly wrong, who's --- is in the sling then?
There's a reason why earth rods are easily obtainable mate, plus if it's a DNO earth facility you can get them to come out and rectify it
Ok so back to the original post then, from now on we install earth rods then? try telling that to most people on the street ' oh it going to be --- pounds extra for an inspection pit, earth rod, lift the flags etc '
As far as getting them to rectify it - you know as well as me thats a bit of a hit and miss statement
As far as a 951 goes, have installed a lot and never known one to come loose but i fully agree with your statement.
In my mind a 951 is better than nothing, and lets be honest most 'sparks' will leave it as they found it and not give a ----.
