L
lofty84
Do you guys have a prefered spotlight. I need to put some spolights in a bedroom and I wondered if there was a make which is good value and god quality. the room size is 8ft x 9ft and I was going to 9 spotlights in it but dont know if 6 would be better.
not sure is there a rule of foot when it comes tot hese things
go for 9. use LED. look for a min' of 300 lumens per lamp.
I use robus fire rated from edmundsons, they are offer at £5 a fitting at the min and the connections are pretty big as well so nice and easy to connect
GU10 (the fitting of the lamp holder) is mains supplied. LEDs fit straight in.
your pm box is full M8
I have fitted plenty of Robus GU10 fire rated in the past, so feel qualified to say that they are absolute garbage. Thin flimsy guards over the connections snap off half the time leaving you with an unusable fitting. The connection box is tiny, as are the connections themselves, don't even think about using 1.5mm cable.
Go for JCC GU10. Good quality but also cheap. I get them for £5.50.
Ansell iCage are also a good fitting.
is GU10 code for led
I will check them both out I take it these are from a electrical wholesalers
