a connector block in an enclosure / chocbox?
Might as well use a proper JB like the J501
Just thought I'd finish off the thread with what I think of the JCC (fireguard range) lights I used.
BRILLIANT to connect to! Plenty of room to fit 2 (1mm) cables into the little box they supply fitted to the light (with great big terminal blocks screwed in). I didn't need the wago's/choc box/junction boxes I had bought just in case!!
The only small downside was the strength of the springs. They were fine when put up, but i needed to take a couple back down and the springs seemed to weaken considerably (This might be common?) when put back up so I had to improvise a little so the lights fitted snugly against the ceiling.
Overall it was a pleasure fitting them. Thanks to those who recommended..
Are you refering to the JCC3?
Was just going to send the picture but cant send unless I write at least 6 words... so I have.
