W
wade88
So after being told off for not using tray, which i now totally understand why, i thought id get hold of a few lengths and give it a go.
Was so much faster, easier, and neater using tray I am totally converted. The last job i did, i think was compared to a badger's arse.... does this look a little more up to par for you guys with the tray?
missed a few ties out but just ran out and took photo before going to work shop before i get pulled up on that one lol ;)
cable management always pays. Take the time to make it look the part and people will always comment good things.
Nice one. What is it being used for out of interest ??
It's a forward/reverse starter, with a 24v DC mini contactor relay in the AB below that the safety circuit will be put through to incorporate 2 ES and a limit switch on the auger lid with the 24v dc signal provided by the PLC that will control the over all mixing line.
This little set up is to incorporate a screw feed auger that will stop start when the PLC commands.
Lovely work Ben!
But why on earth have you put that cable in the top?
I'd have had switch above the tray with both cables entering underneath.
The inside of the switch is pretty congested and bottom of the switch didn't offer much space to neatly navigate the cable. But entering through the bottom.... :/ no euphemism intended..... would definitely have looked a nicer finish.
I agree with bottom entry. Keeps potential seepage to a minimum. Never nice to see moisture or fluids on the top of your gland.
Smut aside.....nice neat job :)
Tidy :-)
We were taught to put 45 degree sections in where you have a 90. Cut through all bar the inner upstand and bend it to 90 degrees. Then cut a 45 dergee wedge out with the upstand along the outer (long) edge and leave 'ears' to attatch it to the bed of the tray.
Like this Buy Newlec Cable Tray, Medium Duty Adjustable Bend, 100mm - NLZM100BN but we had to make them instead of buying them. A right pain at times, but could be almost as rewarding as conduit to do.
Yea I've never had the luxury of being taught anything unfortunately, self taught via my mistakes and then by you lot lol
I'm disappointed...disappointed you've actually put some decent work up for a change ;) can't have the sly digs anymore :(
You've even filed the tray at the top, what has gotten into you - are you feeling okay buddy haha?
All seriousness though, nice job (for a southener) :)
My only criticisms and I'm
Not having a go!, is, as has been said, put a 45 gusset in to allow a shallower bend in the cable
Also don't screw the tray to the wall, as wall mounts/ saddles are fairly inexpensive and set it off nicely and make it a lot easier to feed your zip ties
Novice cable tray user here lol.
To set it off the wall so i could get my cable ties on, i used a 2" square 5mm thick washer. You probably can't see them but it did the trick.
I will be getting a fully stocked supply of tray and trunking and all relevant bits as I definitely preferred using this over my Class A cleating skills ;)
Hey, Mark my old man is from Halifax, i'm part Northerner, part southerner. So i know how to speak properly, but at the same time love Ale.
