why the FCU? for the 3amp fan fusing thing?
yes, because most fan's instructions stipulate a 3A fuse in the supply. this is because they hope that if the fan seizes up , the fuse will blow before it starts a fire. if you don't fit the fuse, then the shady buggers will say it's your fault the house burnt down.
Yea ive never fitted with a fan with a 3 amp fuse, why don't they make 3 pole fused isolators?
On the bright side the FCU, allows you to locally isolate the fan/light and eliminate that part of the circuit in the event of RCD tripping!
