why the FCU? for the 3amp fan fusing thing?
yes, because most fan's instructions stipulate a 3A fuse in the supply. this is because they hope that if the fan seizes up , the fuse will blow before it starts a fire. if you don't fit the fuse, then the shady buggers will say it's your fault the house burnt down.
How about in-line fuses in the fan housing itself?
Wouldn't comply with manufacturers instructions for DP isolation!
