So I've just been to a call out, customer reports a smell of burning before loss of power.
I ascertain that one of two main fuses has gone and there is a slightly charred look about the old VIR cable as it enters the second service head in the flat. Both fuses sealed and I'm not going to start cutting and checking the fuses as I know that this will involve DNO. I'll add that there is no fault here on the consumer's side.
As the crude drawing below shows, there is a main intake with three 80A (or so it says) fuses on the bottom floor in a service cupboard, from there the supply to flat 3 is VIR with a metric csa of between 8-10mm running up through conduit to a rather naff second service head in the flat. EDF have been out within the last week to replace the meter tails because of a burning smell and due to their complete incompetence have upgraded from the second service head to the meter completely ignoring the charred VIR entering the second service head.
I phoned UKPN first to double check that their responsibility ends at the very first service head which they confirmed. Then I was on the phone to EDF to get an engineer out to replace the fuse and also to look at replacing the VIR to which their response was "It's nothing to do with us, it's down to either UKPN or the freeholder to replace"????
I argued the ---- on behalf of the customer but they weren't having it, anyway, my understanding has always been that UKPN cover the supply to the main intake, the DNO cover from the service head to and including the meter and everything after is the consumer's responsibility. My argument was that the second service head in the flat is confusing the issue surrounding responsibility and that the supplier's meter tails go from the main intake to the meter. Anyone have any ideas or can point me in the direction of clear information regarding this matter?
