B
Baker1988
can anyone please link me to an image of a CPC please ...
this is a twin and cpc used mostly in domestic/houses the middle connductor without its own insulation is the cpc
This is swa (steel wire armored) cable used in places where you need protection to your cable like industrial/commercial/supply cables, you can buy this with a extra core and use that as the cpc but normally you use the steel armorings of the cable by useing the gland, here is a pic the outer steel is the cpc
Then there is mi (mineral insulated) cable also known as micc (mineral insulated copper clad) cable this is used where you need to maintain the circuit integrity during fire and stuff like on a fire alarm system as it can with stand a really high temp, it is the copper clad on the outside under the sheath that is used as the cpc
Hope this helps clarify a few things pal
