J
joeblacky
Hi im new here guys and im looking for some advise on some led strip lights that i can use to light a tray ceiling but also that i can dim down with a normal 240v dimmer.
Also the lights need to be as bright as possible because they arr going in the kitchen and are the main light source for the room, so they need to be well in excess of 1000 lumens per meter, probably closer to 1500. I will need a 10m length in total yo do the entire tray ceiling
Also ive been looking at the osram strip lights but im unsure of the components i'd need to run this setup through a dimmer with the osram lights, would someone please be able to advise me?
I cannot really understand what you are trying to do.
You want to put LED strip on the ceiling to light a kitchen?
You also want it dimmable and with 1500lm/m output.
LED strip will not come in the brightness you want you would have to use multiple strips side by side, which may look good or bad depending on the location.
This is not really the best way to light a room, they are accent lighting only.
If you have an LED strip that can be dimmed then you would use a dimmable LED driver for supplying it which may be controlled by a standard dimmer switch but you need to ensure compatibility of the component parts.
You can get led strips of this lux and higher, and a tray ceiling is basically where the center of the ceiling is higher up than the outsides, basically the center is recessed.
What a friendly and informative bunch you are...
