S
shocking_eg
Sounds about right!! lol!! You sure that low setting isn't for turning the water over (through the filter) during non use times, eg maintenance only position??
Lol yep !
Nope there's also an Eco mod for when leaving the hot tub over winter
Drops temp to 12 degrees and runs pumps 24/7
With low current mode on the heater doesn't come on at the same time as the high speed pump
On 32a mode everything can run at once
