Pushing the screws back is a habit I've got into, however one of these is handy, also for 'fishing' in awkward spaces.agree with the busbar behind clamp. wylex seem to be the worst for that. i find that if you push the terminal screws down before inserting the busbar, it usually solves it. worst is when the CU is low level and you can't get your head below to see if it's OK.
and its a problem with `competent` persons......well not being competent ...but replacing competency for carelessnessIts a problem with most cheaper brand mcb's... they don't have a pin guard on the outside of the clamp i lost count of the no' of times ive seen this and believe it should be an ammendment to BS standards on MCB's etc that the design of the clamp dosn't allow this to occur..... otherwise the electrician has to think about his work as clearly alot work in parrot fashion and dont really understand what they are doing.
