My method is:
insert screwdriver
slacken screw to open terminal
slide MCB onto busbar using the driver as a convenient handle
tighten screw
remove screwdriver
sorted.
Some time ago I had to go and look at an intermittent water pump system. When I got there the contactors were clattering around like a pin-ball machine and everything was going spazzy. Turned out someone had forgotten to tighten any of the terminals onto the busbar...
But you cant do that with the loose busbar type. I like the mirror method, (I use a non magnetic Johnsons buddy lol at the moment) hard seeing under the realy low CU,s..
