Remember lads, give em all one more tweak before the cover goes on...... Today's find.
I suspect this isn't anything to do with termination tightness but in fact the busbar pin was outside the mcb clamp when it was tightened seen as though you have a repeated senerio across the mcb's
Its a problem with most cheaper brand mcb's... they don't have a pin guard on the outside of the clamp i lost count of the no' of times ive seen this and believe it should be an ammendment to BS standards on MCB's etc that the design of the clamp dosn't allow this to occur..... otherwise the electrician has to think about his work as clearly alot work in parrot fashion and dont really understand what they are doing.
agree with the busbar behind clamp. wylex seem to be the worst for that. i find that if you push the terminal screws down before inserting the busbar, it usually solves it. worst is when the CU is low level and you can't get your head below to see if it's OK.
Yep I had that with a wylex luckily I seen a spark when switched on in the corner of my eye lol the clamp wasnt on the busbar correctly especially as it was the mother in laws would never have heard the end of it lol
If you cant see under the unit , I allways release the din rail clip and try lifting the breaker off the busbar , just to check after you have tightened it
Pain in the butt, but, fully open the clamp on the breakers then you're virtually guaranteed the bar will be in right.
Pushing the screws back is a habit I've got into, however one of these is handy, also for 'fishing' in awkward spaces.
i use a 4" square one. my old eyes would never see anything in that farty little thing.
and its a problem with `competent` persons......well not being competent ...but replacing competency for carelessness
I agree 100% but my point is the clamp is a small cheap component and this is a issue in the industry and causes many problems so surely like most tech' you adapt to suit as happens throughout any industry... otherwise all drivers would drive like your local vicar and airbags would never have been invented.
i`v come across loads of these though that havn`t been on the right side of the busbar....
a general problem with them is as the driver tip becomes magnetised....so it drags out the screw after you have unscrewed it out fully....so a bit of due care is required here with these....
My method is:
insert screwdriver
slacken screw to open terminal
slide MCB onto busbar using the driver as a convenient handle
tighten screw
remove screwdriver
sorted.
Some time ago I had to go and look at an intermittent water pump system. When I got there the contactors were clattering around like a pin-ball machine and everything was going spazzy. Turned out someone had forgotten to tighten any of the terminals onto the busbar...
