A
Aquaman
Hello all.
I am upgrading my bungalow fuse box to a new split load CU. My circuits on the fuse box were, 1. Cooker, 2. Heat pump and sockets, 3. Immersion heater, 4. Lights.
My new CU is a split load CU, to which I decided to separate the circuits between 2 RDC's in the following way, (From right to left) Main Switch, then RCD 1 with Cooker on a 32A MCB, then Immersion on a 16A MCB, then the lights on a 6A MCB followed by 2 spare spaces.
Then I put RCD 2 with the sockets on a 32A MCB, followed by the shower pump on a 16A MCB.
I did all of the tests such as, continuity, method 1 and 2, IR.
It's a bungalow, and it appears that the sockets are not a ring, but a radial so can't do end to end tests etc.
The problem is that the first RCD trips out as soon as I energise the lighting MCB and the 2nd RCD trips out as soon as I energise the sockets circuit.
Any help would be gratefully appreciated.
If the sockets are a radial and you have them on 32a have you got them wired in 4mm?
The RCD's trip when theres a leakage to earth, i suggest you go through the test procedure again + check that you haven't got the neutrals mixed up.
- - - Updated - - -
I am officially so slow at typing today, thats the second thread in a minute that Dillb has beaten me lol.
The sockets were on one MCB/fuse rated at 32/30 amps, now they're on two.....
I'm not keen on "it appears that the sockets are not on a ring" if you did your testing properly you'd have found that out for definite
I have 3 neutral bars.
I initially thought the sockets would be in a ring, but the end to end tests failed so assume it's a radial as nothing proves a ring circuit.
I thought it may be a borrowed neutral and will check each neutral bar tomorrow.
Anywhere else I should check for a BN?
Why have you decided to load the one rcd with both radial circuits,which presumably are supplying all your sockets and on 32 amp mcb (4mm assumed) ? What is the reasons for this decision
It was definitely a ring some time ago, I presume the T+E is 2.5 and 1.5 in your case if protected by 30A fuse, where now then you have 2 radials each on 32A mcb’s, NOT GOOD. Makes me question, are you really should be doing this…
You're right Trev. Will go through it all again tomorrow.
